Disables the sending of LLDP-specific SNMP traps on the specified port or ports.
all | Specifies all ports on the switch. |
port_list | Specifies one or more ports or slots and ports. |
Disabled.
If you do not specify any ports, the system stops sending LLDP traps from all ports on the switch.
The following example disables sending LLDP SNMP traps on all switch ports:
disable snmp traps lldp ports all
